Ejector Pin Post Processing Untrim Problem
I am having an issue with a library model in Moldwizard.
When using the ejector pin post processing it works correctly to trim ejector pins down to a surface, but I get an error when trying to untrim.
The error says "Internal error: an attempt was made to access an attribute not in the relevant class"
I assume there is an attribute that needs to be set up for this pin and it isn't working properly.
