NX 9.03 - Point in Sketch and negative draft
Hi all,
1. After updating NX9 to last built 9.0.3.4 there is a situation, when I want to make a point in a Sketcher...
I click to "Point" icon and to a display space as normally. After that I have always 2 points in the Sketcher - one click -> two points on the same position.
Do you have somebody the same experience?
2. Is possible to make a negative draft in NX9? ...like in Catia?
I can't make a draft < than 0.
For example...I have a cylinder and I want to make a shape like drop in top view with Draft Body function
Thank you in advance for answers
Jan
Jan
RE: NX 9.03 - Point in Sketch and negative draft
NX 9.0.3.4
NX 10 (Testing)
Windows 7 64 (Windows 8.1 Tablet)
I will not ask you why
- have you tried to reverse the vector ?
Tomas
