Topmost VB form name - active form
How do I find out the name of the topmost form
in a VB6 program.
I can determine the hWind but I do not know
how to find out the VB name of the form.
b1724@110.net
RE: Topmost VB form name - active form
As you can get the windows handle the following should suffice.
First place the following API functions in a module:
Declare Function GetWindowText Lib "user32.dll" Alias "GetWindowTextA" _
   (ByVal hWnd As Long, _
    ByVal lpString As String, _
    ByVal nMaxCount As Long) As Long
Declare Function GetWindowTextLength Lib "user32.dll" Alias "GetWindowTextLengthA" _
   (ByVal hWnd As Long) As Long
Create a Label control and name it 'lblWindowText'
Then insert the following code (enough here for you to have a play around with!) in say, the click event of a command button:
Dim intWinTextLength As Long
dim lngResult as Long
Dim strWinText As String  ' receives the copied text from the target window
'Get the space required for the window title
intWinTextLength = GetWindowTextLength(hwndWin) + 1 'add one for null character
lblWindowTextLength = CStr(intWinTextLength - 1)
'Get Window text
' First, determine how much space is necessary for the buffer.
' (1 is added for the terminating null character.)
intWinTextLength = SendMessage(hwndWin, WM_GETTEXTLENGTH, ByVal CLng(0), ByVal CLng(0)) + 1
' Make enough room in the buffer to receive the text.
strWinText = Space(intWinTextLength)
' Copy the target window's text into the buffer.
lngResult = SendMessage(hwndWin, WM_GETTEXT, ByVal intWinTextLength, ByVal strWinText)
' Remove the terminating null and extra space from the buffer.
strWinText = Left(strWinText, lngResult)
' Display the result.
lblWindowText = strWinText
Have fun
Derrick
