Member with combined flexure and axial forces
AISC have a provision for members subjected to flexure and axial force given in Chapter H (H1.1)
The given formulas require that the combination of required strengths devided by the available strengths for both axial and moment not to exceed 1
Is there any allowance for slight overstress? (i.e. assuming the result is 1.04 or 1.09)
Some engineers accepts 5% more, some other say within 10% is OK (?) I am just trying to see if there is any standard/ practice that justifies any of these claims..
RE: Member with combined flexure and axial forces
The greatest trick that bond stress ever pulled was convincing the world it didn't exist.
I don't have my manual with me, but the interaction formula allows for 8/9 x moment strength ratio for most columns.
Try putting a knee brace on your beam-column.
More often than not I can find enough just by tightening my belt. I don't blindly accept a value of 5-10% over (That's un-true, if I'm checking an existing structure and I get 5% overstress I call it good enough without a recheck).
