How is this calculated
Hi
Can some one help with (see attached):
whats the highlighted header called "Y over scored"
Whats the formula for calculating this ?
RE: How is this calculated
Presumably the value would be 1,176.3 if they showed the distance to its fourth digit.
I am actually trying create a spread sheet for this calculation. Thats the reason I have to understand couple of these values & how they were calculated.
From your help, I understabd the formula is basically. I have attached better picture.
moment=force x distance
With this I am able understand all the values for the column "Momemt at B-B".
But, further down, there is a calulation for moment at A-A.
here I don't understand the numbers red circled numbers 16.09, 10.09 & 7.3
Are these the distances from point of load application to Section plane A-A?
Also, why is the green circled force changed. Do you guys think this is mistake ?
Yes, to find the moment at A-A you multiply the forces by the distance of the centroid of each force from the axis.
And yes, the number that is changed looks like a mistake; you should tell whoever gave you the drawing.
Doug Jenkins
Interactive Design Services
http://newtonexcelbach.wordpress.com/
The value of "93.06" in the moment at A-A calc should be the value of "193.06" from the table - typo error!
Normally, I use FEA tools and get done with. This way, I have really lost touch with basic calculations. Also, I don't want ask too many questions at one point, that's why I am asking in parts.
Question : Torsional Moment
I understand that this the kind of force generated due to effect of wind force on the element like a Banner, arm or a signage that sticking out from the center line of the pole. Thus generating the twisting effect on the pole (torque)
1. I see that the 183.16 is the force on the banner, but whats the value (2.58) underlined? I guess its the horizontal distance from the pole center to the center of the banner (thanks oldrunner).Also I looked in aashto code, probably its very basic, that's why its not showing it there.
I would appreciate if you can help me with where in aashto LTS i could find this.
2. Is there a any where online a revision history of aashto code LTS. I need to know what changed from LTS3 to 4 to 5 to 6. Is it documented anywhere.
3. I know that EPA is calculated by area x coefficient of drag. Is this a project area or surface area
I have included the spread sheet I have so far.
sect A-A looks to be 3.41' above the ground (sect B-B) ... in the calc (with the circled numbers) 93.06 should be 193.06, and 7.3 should be 7.09 (to be consistent with the other parts of the calc.
