Overdutied Equipment
I have run into a situation where some power correction units are overdutied. The manufacturer has rated them at 10kA whereas the available fault current is around 29kA at 480V. I am thinking that I may be able to continue using these if current limiting fuses are installed upstream.
Looking for thoughts/opinions.
Thank you in advance.
RE: Overdutied Equipment
If you're fusing at the cap bank location then a CLF should take care of the high fault current concern.
If you are applying the fuses upstream, then you have to pick a rating that will handle the total load. In this case, the CLF rating may be too large to protect a downstream capacitor bank.
Some automatic power factor correction units come with reactors that are intended to reduce harmonics, so I wouldn't expect that adding reactors upstream of your PFC units would affect their performance.
I would also check with the manufacturer to see if there are any solutions they would recommend.
Did you use the resistance of the cable or the impedance tables? The voltage drop or impedance tables include cable reactance and will yield a shorter length.
Have you looked at the impedance of a higher voltage rated cable? Higher voltage cables tend to have a higher reactance per foot due to the greater conductor spacing as a result of the thicker insulation.
This probably won't get you down enough, but if a standard rating reactor needs just a little help, you may get if from longer cables.
Bill
"Why not the best?"
Jimmy Carter
