How to display assemblies in Powerpoint
I am looking for a way to add to a presentation of powerpoint, a full assembly created by Solidworks.
Is anyone have the idea how to do that?
RE: How to display assemblies in Powerpoint
FYI, [ALT]+[PRINT SCREEN] copies only the active window, not the entire screen, to the clipboard.
Is this what you're looking for?
Ken
"The attempt and not the deed confounds us."
In the meanwhile I have found very nice software at www.hooods3d.com that add to the windows Acttive-X a utility that enable to add parts and assembly of solidworks or Pro-e to powerpoint.
In the meanwhile I have found very nice software at www.hoods3d.com that add to the windows Acttive-X a utility that enable to add parts and assembly of solidworks or Pro-e to powerpoint.
In the meanwhile I have found very nice software at www.hoops3d.com that add to the windows Acttive-X a utility that enable to add parts and assembly of solidworks or Pro-e to powerpoint.
In the meanwhile I have found very nice software at www.hoops3d.com that add to the windows Active-X a utility that enable to add parts and assembly of solidworks or Pro-e to powerpoint.
Can you do this with other software output? Powerpoint does some very limited animations. You could create a moving gif or break the solidworks assembly into movable pieces. The easiest is to just use E-drawings. If you insert an object you can link to SWorks from the slide.
But if you move this onto someone elses PC it is probably not going to work.
Crashj 'on the other hand' Johnson
