Wilkinson Power Splitter(100MHz), 100 Ohm resistor position?
I would like to design a four way Wilkinson power splitter at 100MHz. I would like to split the 1W power in to two Wilkinson splitters, starting the design on Microstrip. The four-¼ wavelength would be realised using 75-Ohm coaxial cable, and each cable would terminate in to 50 Ohm. I am aware of the design at www.uksmg.org/split.htm. My question is could I place the two 100-Ohm resistors at the start off each separate pair of ¼ wavelength coaxial splits on the circuit board...a little confused this morning....Thanks!
