FEMAP : Combine surfaces into 1 surface
I facing some problem to joint 2 or more surfaces into 1 surface..Anyone who can solve it?
RE: FEMAP : Combine surfaces into 1 surface
Then go to the Meshing Toolbox under Combined/Boundary Surfaces and select Add Surfaces.
Finally (if desired) use the combined/composite curves / add by point to merge curves.
Seif Eddine Naffoussi, Stress Engineer
www.Innovamech.com
33650 Martillac – France
Thanks for the answers. Really appreciate your help.
