part design assembly problem.
RE: part design assembly problem.
hi,
your question is not clear.Do you want to assenmble all these parts into one single assembly or you want to make a single solid with the help out of these three views?
For the latter you can use a solid combine.However you can combine only two sections at a time using solid combine.Please come back if you are not clear.
It looks like they are already combined...there is only one body. Inside that body you must have used several shape constructors (like pad) to create what is shown on the screen. The body is all of them combined together...CATIA does not view the shapes inside a body as being independent.
