Solution: Draftsight Alias Commands not sticking
My DraftSight alias list was empty and if I imported the included list or manually entered new ones, they would disappear when I closed the options dialog box or clicked 'apply'.
Searching Google for "DraftSight aliases disappear" brought me to: "Draftsight Alias Commands not sticking" (thread1480-331534: Draftsight Alias Commands not sticking). There was no solution posted and the thread is now closed. I found a solution that worked for me, so am posting it here for reference.
In my case, the issue was that the Alias File Location was not set. To resolve:
1) Open the options dialog box:
3) Under 'Interface' click on the plus mark beside 'Alias File Location'
4) Click 'Browse' and navigate to the 'Alias' folder in the DraftSight AppData directory; mine was here:
Once that is set, new aliases should stick. I had to re-import the original list so that I was not starting from scratch. To do so:
1) Again in the options dialog box, select 'User Preferences' from the buttons on the left
2) Under 'Aliases' click 'Import...' and locate the alias.xml file in the DraftSight program files; mine was here:
Dave
Tools > Options...
2) Select 'File Locations' from the buttons on the left3) Under 'Interface' click on the plus mark beside 'Alias File Location'
C:\Users\*username*\AppData\Roaming\DraftSight\1.2.285\Alias
C:\Program Files\Dassault Systemes\DraftSight\Default Files\Alias
Dave
RE: Solution: Draftsight Alias Commands not sticking
I appreciate that post. I am also having trouble with my alias commands. I have checked the alias folder and that is fine. When make a new alias command, it saves in the alias file but when I execute the command it does not work. For example I wanted to use bb for Break. I put it in the file and then use the refreshaliases command and reload my alias file. It says it is reloaded and then when I type in bb, it does not work. It returns the following Enter a Command now Please !!: bb
Unrecognized command BREAK. Press F1 for help. I have tried pressing F1 and dug through everything I can find but still no solution. If I just type in break or split the command works fine.
I upgraded to the latest version yesterday to see if that would fix it and nothing has changed. Exact same results. However, when I upgraded I lost the online map function. Where did that go and will it come back ? That is one reason I bought the pro version.
Any help is greatly appreciated.
Drafto
Drafto here. I am making progress on the alias mystery ! Also, I figured out where the online maps went and have those back.
Now I am really starting to love the new version.
Does anybody know how to make the weird circle thing that pops up every now and then go away ?
Thanks and best wishes to all.
