Check Status of all Interpart Links in a Given Part
Hi everyone,
In NX 7.5 is there a quick way to check the status (ie. "Up to Date", "Not Up to Date") of ALL interpart links in a given part file? I can double-click each linked feature in the model tree and it will tell me one at a time what the status is, or I can call up an information window about each feature to the same end, but since I have many linked features, this can take a while.
Thanks!
RE: Check Status of all Interpart Links in a Given Part
Perhaps turning on the "status" and/or "out of date" columns in the part navigator would help.
www.nxjournaling.com
Open the Part Navigator, place your cursor over some 'white space', press MB3, select the 'Columns' option and toggle ON the 'Out of Date' item. Now you'll have a column in the Part Navigator showing you the status of each feature in your model.
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Digital Factory
Cypress, CA
Siemens PLM:
UG/NX Museum:
Thanks, that's exactly what I wanted!
