Optimization
Optimization
Hi, i recently began working on solid edge ST7, I have been able to do everything I need to do, except to optimize a metal sheet from an assembly study.
The problem I have is that I can’t select physical properties as an objective for the optimization when I realize mixed and united bodies mesh type. It needs to be this type of mesh because the model contains frames and other parts and if I select a tetrahedral mesh type I can’t select frames.
I hope someone can tell me the answer or if am missing something.
Sincerely TeoT.
Sincerely TeoT.
