Power System Stability
I have a synchronous generator (50Hz, H=8 MJ/MVA), delivering active power of 1pu to an infinite bus at V=1pu through two 100-km TL lines with reactances of XL=XL2=0.5pu. The transient reactance of the generator is X'd = 0.2pu and the internal transient voltage E'=1.4pu. The transformer reactances is XT=0.1pu.
I've to plot the power angle curve and determine the rotor angle.
There is also added questions when a fault occurs. Can anyone point me in the right direction on where to look/any similar examples?
Thanks in advance
RE: Power System Stability
That has the smell of coursework. The numbers are too convenient.
Bill's link to the FAQ is a good place to start.
cmunda200 (Electrical),
This forum may not give you a good guidance on this. The way forward would be to refer some good text books as waross (Electrical) has indicated.
See: IEEE Std 399-1997, IEEE Recommended Practice for Industrial and
Commercial Power Systems Analysis.[Brown Book]
ch. 8.6.2 How stability programs work
