Aircraft W&B check
Aircraft W&B check
Hi All,
I have been tasked to check the weight & balance of a Q400 aircraft if a stretcher kit is installed at a specified reference point. Could someone outline the step-by-step procedures on how to do this? I have the stretcher weights and arms, weights of the seats to be removed and the location.
Note: By doing this check, I would be able to determine the worse case scenario, that is, how many stretcher can be installed with the how many seats to be removed.
RE: Aircraft W&B check
A good place to go for basic weight and balance calculations is http://www.faa.gov/regulations_policies/handbooks_...
Hope this helps.
you know where you want to install the stretchers (defined on a LOPA), and how many seats are removed to allow this. personally i'd be surprised if there was much difference (between the stretcher and the removed seats, particularly between a loaded stretcher and the equivalent number of pax) ? i mean a stretcher has to remove at least 3 seats (ie 6 pax) ?
there are two ways to do this ...
1) as an absolute ... start with a specific airplane LOPA, remove seats, add stretchers, or
2) as an increment ... just calculate the delta due to removing seats and adding stretchers.
btw, "worst case" ? why ? surely stretchers would be loaded closest to the front of the cabin (it'd be Really hard to maneouvre a stretcher down an 18" aisle). I'd put the stretchers at the front of the cabin, moving aft as I have to install more.
Look up "Design Considerations for Minimizing Hazards caused by Uncontained Turbine Engine and Auxiliary Power Unit Rotor Failure" from the FAA website (AC 20-128A).
STF
You not only need the procedure, but the same manuals must have the C of G / W&B *limits* listed.
Some aircraft can be on the edge of their limits due to modifications over the years, so small changes can be important.
"Some aircraft can be on the edge of their limits due to modifications over the years, so small changes can be important." ... i think that's why you should do an incremental W&B (rather than starting with some specific a/c) and it is up to the installer to make sure he's operating within the Flt Manual limits. In fact, if you're doing the STC to install the stretchers, your LOPA should define where stretchers can by installed and final cabin arrangements (if you have stretchers in the rear of the cabin, do you install seats ahead of them, presumably after the stretchers, or do you fly with an empty cabin (other than the stretchers) ? The problem I see is that there are many possible configurations, so doing a W&B to cover them all seems extensive, and I think it'd more straight-forward to say "recalc the W&B for the strethers installed, each stretcher weighs ZZZlbs, stations as per LOPA ...".
Unless you're doing this for a specific a/c ...
These are the steps that I will take to determine if installing the stretcher will change the C of G.
i) Calculate the effect of seat removal i.e. total weight and moments. 1 stretcher = 3 seats removed, 2nd stretcher, another 3 seats removed and so on.
ii) Calculate the stretcher installation effect i.e. stretcher weight added at known locations/stations.
iii) Calculate the overall effect i.e. effect of seat removal & effect of stretcher installation (total weights removed/added & total moment)
iv) Comparing the final figures with the aircraft W&B records to see if it will have an effect on the C of G.
End///
then one patient compared to up to 6 pax (and their carry-on) ...
sounds like it's a wash to me
how did you account for "up to" 6 pax ? ('cause i've got to believe that 1 loaded stretcher weighs less than 6 pax.)
Too little weight in a given location can be just as dangerous. Never assume that you can remove weight and be safe; the weight might be necessary to keep that end of the aircraft down.
Also, never assume that the change you're doing is less than the ever shifting passengers and thus not important. That is all taken into account in the limits, and you cannot assume that the passengers will or will not actually be there; pushing up against the mins or maxes in the this direction or that.
W&B is something that has to be done 'by the book', double checked, and by qualified persons.
Good luck.
You can be horrified at times when, what the aircraft actually weighs, and where the CG really is, compared to your calculations, are far apart ,and at other times pleased when they are where you figured they should be.
I have had aircraft where they have had a factory weight and balance be as much as 30 pounds different and the CG be over 3" away from the factory's numbers.
B.E.
You are judged not by what you know, but by what you can do.
There seems to be something about weight and balance that confuses a lot of people.
A5130, first is it just the net weight change you are trying to define or are you getting in to the operation aspects of the weight and balance i.e. the "as prepared for service weight". The operator should have a definition for what the "as prepared for service weight" is (often it will be the same as whats in the OEM's weight and balance manual but not always). It may include the mass of the flight crew, the flight attendants & associated bags, as well as food carts, etc ,etc.
Yes that is on small single engine aircraft. It was common practice for some manufacturers to not weigh the aircraft as they came off the line, and use a calculated weight, based on an average of the aircraft weighed further ahead on the line. And the 30 pounds I was talking about was over not under.
Without naming names the companies were based in Wichita Kansas.
The thing that bothered me about the original post was that the questioner appeared to be removing seats and adding stretchers from the front of the aircraft, which depending on how many he did, would tend to make the aircraft, tail heavy, which prompted my comment about weighing it when he was done.
There was an airliner manufacture that until recently weighted the aircraft twice and used the lower of the two weights.
I would add that if the aircraft was weighed after installation, an exacting record of the aircraft configuration needs to be made, as there nothing worse that the conversation along the lines of, we weighed the aircraft 6 months ago but the records don't define which LOPA (or LOPA revision), or part there of was fitted.
