Proper Modeling for Expansion Joint in C2
Could anyone share how to model an expansion joint with limit rod tightened on one end in Caesar II?
RE: Proper Modeling for Expansion Joint in C2
The only realstic route to obtain proper results for a typicl rubber EJ would be with a calibrated test rig.
There are many reasons for this, for example, the longitudinal rotational spring rate of this kind of EJ is a fuction of axial compression. It is not a constant value as would be found in a metallic unit.
However, in most cases, for the normal range of imposed movements, the forces and moments developed by a rubber EJ are so small as to be insignificant.
