Class V seat Leakage Test procedure
Hi All,
I have an HC-30 Ventil control valve test bench and would like to know how to utilised it for testing class V control valves at maximum differential pressure across the seat.
Can anyone with similar test bench advise a procedure for testing such? Appreciate your response..
Naresh
Naresh
RE: Class V seat Leakage Test procedure
*ANSI/FCI 70-2-1991 standard for reference to create leakage class procedure.
My Motto: Keep calm and never give up.
http://www.nssn.org/search/DetailResults.aspx?doci...
The same requirements are included in IEC 60534-4 as well:
http://webstore.iec.ch/webstore/webstore.nsf/artnu...
Hope this helps,
’NGL
