LVT Generator
LVT Generator
What is the difference between a Standard Generator and a LVT Generator? Kato's Generator Selection Chart indicates that a 350 kW Standard Generator can start a 50 HP motor with a 15% drop in initial voltage. If a LVT Generator is used than a 250 kW could start the motor with a 15% drop in initial voltage. Anyone know difference between a Standard and LVT generator. Does the LVT generator have a "beefed up exciter" maybe?
RE: LVT Generator
The size to voltage drop comparison looks a lot like comparing a SE or shunt type generator to a PM or AREP type generator, here is a nice explanation of the differences,
http://www.leroy-somer.com/documentation_pdf/4124a...
Hope that helps, Mike L
