SURFACE DEFORM IN GSD
Is it possible to deform a face in GSD like shown in the attachment. There is no license for a free form.
In attached PDF file this was done in Cimatron surface deform (deform from point to point).
RE: SURFACE DEFORM IN GSD
Win 7
23SP5/24SP3, 3DVIA Composer 2015
I think they are different.
Is it possible to move the control point and keep the length of the two edges unchanged?
possible in GSD to do something similar to what I've posted before. In GSD wrap curve definition or shape morphing deformation definition can be used.
You can eventually build the new curve as an electrical bundle (EHI license) and set the curve length, or use Product optimizer to have catia find the proper tension parameter of your new curve in order to have the length you want.
If you need to do this only once, you can play with the tension parameter yourself and find the best value to match the length you need.
