Gear Design for maximum fatigue life- Papers and Texts?
Hello Everyone,
I'm trying to design a set of gears to maximize the bending fatige life, within a given center distance and face width. I'm trying to learn how the pitch, pressure angle and helical or spur will effect the fatigue life of the gear. Can anyone point me towards a suitable text book, or a few papers that might be beneficial?
Kurt.
Kurt.
RE: Gear Design for maximum fatigue life- Papers and Texts?
Below is a list of books that I'd suggest you try to get hold of. Any one of them will be of great help to you. Most University libraries will contain at least one of these books.
Download a trial version of a gear calculation program. As a student, I'm sure that it would be free. I'd suggest a program called KISSsoft.
On The Geometry of External Involute Spur Gears - Khiralla
Spur Gears - Buckingham
Dudley's Gear Handbook - Dudley/Townsend
Handbook of Gear Design - Maitra
Analytical Mechanics of Gears - Buckingham
Gear Engineering - Merritt
Gear Design, Manufacturing & Inspection Manual - SAE International
Fundamentals of Gear Design - Drago
PhD Student, and Product Support Engineer for Caterpillar Motorgraders.
Better off for you to hone your researching skills and try a bit harder as all the information you seek is easily available on the net..........if you take the time to look and learn how to use the appropriate search queries.
I just did a very basic search via Google and received 264,000 hits related to this subject.
For example, my research is in combustion modeling and I could point someone to an exact text or paper that I have read based on the information they are looking for.
To save you time; the best thing that I can recommend you do is to download a trial version of KISSsoft. Then you can play around with the parameters and see in real-time how the changes you make affect the life of the gear set.
http://www.kisssoft.ch/english/downloads/index.php
Optimizing the design of a gearset for particular requirements is definitely an exercise in compromise. This is one of those tasks where experience is invaluable. An experienced gear designer can take a look at a set of design requirements and fairly quickly provide you recommendations for a gear design that is pretty close to optimum.
As gearcutter noted there are some excellent software tools (Kissoft, UTS, etc.) that simplify the task of iterating your gear design to produce an optimized solution by tweaking variables like material or tooth geometry. These software tools can be quite expensive, but since you work for Caterpillar engineering I would imagine you could get access to the gear design/analysis tools the company uses.
As a PhD student, if you want an analytical approach to optimize a gearset for certain requirements then purchase a copy of AGMA 901-A92 "A Rational Procedure for the Preliminary
Design of Minimum Volume Gears". This document covers the same approach used by most software applications.
Best of luck to you.
Terry
