Modular Geocellular Drainage Tanks
Hi there.
Does anyone have any experience of working on, either theoretically or actually, modular cellular plastic drainage tanks? I would be interested in hearing your opinions positive or negative. In the UK they are used for storage and infiltration.
RE: Modular Geocellular Drainage Tanks
I guess I can draw my own conclusions 10 weeks later smile
I missed this before.
I've done a bunch of hydrologic models on infiltration stormwater management systems. From a modeling standpoint, they're all basically the same. Not sure what your question is.
Hydrology, Drainage Analysis, Flood Studies, and Complex Stormwater Litigation for Atlanta and the South East - http://www.campbellcivil.com
The cheap ones from the local hardware store invariably collapse. glasses
As a chem eng/metallurgist the first part of any answer I give starts with "It Depends"
I think you would be better off using HDPE Pipe instead. It may be a little more expensive than these modular units, but they would last longer.
