Guarantee Coal
Guarantee Coal
Dear All,
I would like to ask how to proceed with the performance tests on a coal power plant if the fuel quality is different from the contract? how do we create a correction for the thermal performance of the plant. Guarantee coal is different from the actual coal purchased (lower quality).
Thanks.
Thanks.
RE: Guarantee Coal
Proper documents should address guarantee conditions for a variety of "probable" coals that the plant may use.
A lot depends on the specific boiler guarantees that you are trying to meet..... is it heat rate ? emissions ?
You may have to bring in a third party and re-negotiate a new acceptable performance test.
MJCronin
Sr. Process Engineer
RE: Guarantee Coal
As well as emissions and heat rate, you may need to look at a number of the off-spec coal's characteristics, such as its grindability, whether it be free-running, sintering, slagging, caking, etc; depending on these, you may encounter major operational problems if you attempt to fuel this plant with a coal other than with the type for which it was designed.
CR
RE: Guarantee Coal
I want to know how to proceed if the coal that will be purchased is not the guarantee coal but is within the range of the coal design envelope.
