Analysing a scissor lift table in NX 9
Hello guys.
Im making a scissor lift table and struggle abit with the FEA.
I have never tried this kind of coupled mechanism analysis before, so have patience.
I have tried several different methods of coupling the two parts trough center holes where it will have an axle / bolt. There is also a cylinder acting, but this is simplified by a rigid RBE2 element, as max load will occur at the most lower position. (I have also tried CROD). The load is a total of 18kN total. The scissor mechanism is coupled by a manual coupling, and i have also tried RBE2 elements only.
The stresses get far higher than i have expected. Any input? Thanks.
FEM and SIM file:
https://dl.dropboxusercontent.com/u/3095226/scisso...
the scissor table is similar to this in the mechanism:
FEM and SIM file:
RE: Analysing a scissor lift table in NX 9
See attached image.
Tomas
Thanks for the tip!
