NX Basic Dimensions with Quantities
Is there a way to get the basic dimension box to go around a quantity? For example
________
|8x .250 | instead of
_______
8x |.250|
Or the same on an angle. In the ASME y14.5-2009 it shows the quantity inside the basic box.
NX 8.5.2.3
RE: NX Basic Dimensions with Quantities
Y14.5M-2009 section 1.9.5 says "Where used with a basic dimension, the X may be placed either inside or outside the basic dimesnion frame."
The software meets the spec, so getting a toggle for company preferance will require an enhancement request. My guess it would get a low priority since the code already 'meets' the standard.
Ben Loosli
Can you show me where it says that, so I can forward on to the other people to prove that to them?
Thank you!
NX 8.5.2.3
Nevermind, I just searched your quote and found it. Thank you very much
NX 8.5.2.3
