calculate the force and torque
RE: calculate the force and torque
shear modulus is not the shear strength of the material. The stress of 8800 ksi is was higher than any material can achieve in shear.
What is value of Shear strength of the Material?
What is value of Shear strength of the Material for A286 Alloy (AMS 5731 or 5732)?
Fsu for A286, refer AR MMPDS-01, table 8.1.2(b), is 85ksi.
these are custom threaded studs ?
Thanks for sharing...
hey,
In your calculation u calculated total torque applied in last in that case u taking 317lbf force is applied how it is taken and any other way you have for calculating the total torque??
