JT viewer for NX assembly in TCE
How to add JT viewer for NX assembly in TCE?? I did below method though its not showing up in JT preview.
1. Toggled on 'Save JT preview' in NX assembly. (JT viewer is not created).
2. Export=>JT..from NX and than imported as direct model in item revision (JT model is created however its no showing up in JT preview)
Saving JT is working for piece parts however its not woking for assembly.
RE: JT viewer for NX assembly in TCE
Assemblies in Vis work the same way as they do in NX, by collecting together JTs of components.
So you need to select the BOMView in TC, and view that in your viewer, which will then load the components.
www.jcb.com
NX 8.5 with TC 8.3
I am looking for the same option
Didier Psaltopoulos
http://www.psi-cad.com
www.jcb.com
NX 8.5 with TC 8.3
