Variable rads
Variable rads
Variable rads
In edge blend you can put in a variable rad for example a 5mm radius in one corner of a edge down to a 1mm radius in the other corner of a edge. Is there a way to do this in face blend if so how can I do this?
Thank you.
Regards Daniel lamb
RE: Variable rads
Hi Daniel,
You can do it in the normal edge blend command in NX8.5.
Regards Carl
www.jcb.com
NX 8.5 with TC 8.3
RE: Variable rads
In the face blend command, change the radius method to "law controlled"; this will open up options for controlling the radius along the blend path.
www.nxjournaling.com
RE: Variable rads
Wonder if I can delete my previous post for not reading the question properly. It's been a busy day!
www.jcb.com
NX 8.5 with TC 8.3
RE: Variable rads
Just 'Red Flag' it and ask that it be removed. Of course you'll need to ask that your second post, asking how to remove the post, and mine, telling you what to do, also will need to be removed winky smile
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Digital Factory
Cypress, CA
Siemens PLM:
UG/NX Museum:
RE: Variable rads
And this one John, thanking you for the info.
Perhaps I'll just leave it there for all to see my error.
www.jcb.com
NX 8.5 with TC 8.3
