Equipment ( High Transformer, Control Cabinet, Fan and Blowers ) Safe Distance inside a Container
Hello Guys,
I am tasks to put inside to an offshore conatiner the following equipment: High Volatege transformer, Control Cabinet where the high volgate connetion must be terminated, and Fans for the air-cooling of the equipment.
My problem are the available space. What would be the standard clearance that is considered to be safe from each of my equipment? like what woul be the safe distance and what particular standard that I must read for me to make sure that my equipemnt lay out will be approved by the DNV during Testing and Certification. This is my first project and I am kind of new in this job.
I hope you will helpme guys.
Thank you so much.
Meggerer( Electrical)
RE: Equipment ( High Transformer, Control Cabinet, Fan and Blowers ) Safe Distance inside a Container
What voltages are your "high volt" transformer leads and connections?
How the high volt sides shielded, or are they "open copper" within the box?
Sorry guys, I come back to you just today.
My Transformer was 22KW. the secondary side was 609/400v.
But thanks for the standard reference Catserveng.
I saw it helped and got some inputs to it.
Thanks guys.
