Classification ER70S-6
Issue with classification ER70S-6 - SF 5.18 and A No.1 classification.
ASME IX QW-442 says maximum 1.60 Mn and Si 1.0 for A No.1
ASME II C SFA 5:16 says Si 0.80-1.15 and Mn 1.40-1.85 (same as AWS 5.18)
Why these 2 differences and what should I use?
We have a 2.4 mm LNT 26 Lincoln filler material with Si 0.82 and Mn 1.47
Patrick
Patrick
RE: Classification ER70S-6
Fillers with flux; SMAW, FCAW, and especially SAW have dramatically different As-Welded chemistries when compared to the bare wire used. The flux supplies most of the alloying elements.
