NX8.5 Attributes Callout Not passing from assembly to Drawing
I am having a small issue with attributes not being passing down from the assembly to the master drawing.
For Example I have a five part assembly in NX. I have assigned the "callout" attribute to the components in the assembly.
Now when I make a new drawing (using master model concept), I insert a new parts list, these callouts show up in the parts list just fine.
Now when I go back to my master assembly and modify the assembly components callout attributes, these changes do not reflect the changes that I made in the assembly, in the drawing. In the drawing these attributes still display the old Callout. Also if I right click on the parts in the assembly navigator while in the drawing and review the attributes the values do not match what I changed in the assembly. Is there something I could be doing wrong?
Shane
Shane
RE: NX8.5 Attributes Callout Not passing from assembly to Drawing
is this in Teamcenter ?
