Supporting steel structure on compacted crushed rock
Hello Civil Engineers. Pardon my ignorance. I am a mechanical engineer designing a steel structure for a construction site.
Basically it is a 30ft x 12ft platform with 8 legs (can be more legs). The fabrication plus the large tooling it carries weighs 30 tons (60,000 lbs).
The thing is intended to sit outside on a prepared compacted area. Here is my question. If for simplicity each leg carries 60000/8 legs= 7500 lbs.
Lets say I put a square steel foot on the bottom of each leg 12" x 12" (144 square inch). 7500 lbs/144 in^2 = 52 psi (or 7500 lbs/square foot) load on the aggregate pad.
Assuming the load is evenly distributed on all 8 legs to simplify. Is there a specification I can use to make sure the compacted pad is up to the job?
I want to be able to say something like " make 20 ft x 40 ft pad 3 feet thick of aggregate x. Compact until it meets Proctor(?) test ?% compacted."
The pad is elevated in an are where water accumulation is not an issue. Again, pardon my ignorance. I would appreciate some help in how to spec this pad
so that it can handle the weight of my structure. Thanks. The contractor uses crushed scoria rock but I can spec something else if need be.
RE: Supporting steel structure on compacted crushed rock
It is a surface mine. Construction site was a little misleading.
The open pits definitely employ geotechnical people for a number of reasons.
I'll see what I can find out and post my results.
assume that compacted aggregate will spread the load at about 45 degree angle.
3 feet thick sounds like overkill, 12 inches would likely be more than adequate, but really depends on your subgrade strength.
wet it and roll it with a vibratory roller until it is well compacted. you really can't use proctor for crushed rock. you might consider using dense graded aggregate base course material.
