Stellite Alloy in Amine environment
Hi @Steamdog, As you mentioned in thread408-255437: STELLITE OR ELECTRO NICKEL PLATED, your working partner suggested that Stellite alloy should not be applied in Amine environment. Did he/she mentioned the failure situation or the reason. Thanks!
RE: Stellite Alloy in Amine environment
Thank you very much in advance for any information:)
Anyone with information is welcomed. Thanks!
