Use of multi-segment heads on pressure vessels
Is there any restriction such as thickness, diameter or hazard level for using multi-segment heads on pressure vessels as per ASME VIII or AS 1210?
RE: Use of multi-segment heads on pressure vessels
Cheers,
gr2vessels
