When using the Inch standard, is it mandatory to use 3 decimals in the feature frame?
I have always seen 3 decimal places in the feature frame when using the inch standard. It seems worthless to include the superfluous zeroes in the dimension, just for the purpose of consistency with the feature frame. For instance, the dimension is .xx, the positional tolerance is .xx. Does correctness require the trailing zeroes in the FCF and/or the dimension?
RE: When using the Inch standard, is it mandatory to use 3 decimals in the feature frame?
See ASME Y14.5M-1994 section 2.3.2 d "Where basic dimensions are used, associated tolerances contain the number of decimal places necessary for control. The basic dimension value is expressed with the same number of decimal places as the tolerance."
Posting guidelines FAQ731-376: Eng-Tips.com Forum Policies http://eng-tips.com/market.cfm? (probably not aimed specifically at you)
What is Engineering anyway: FAQ1088-1484: In layman terms, what is "engineering"?
Times change...
Per ASME Y14.5-2009 ¶2.3.2(d) "Where basic dimensions are used, associated
for control. There is no requirement for the basic
dimension value to be expressed with the same number
“Know the rules well, so you can break them effectively.”
-Dalai Lama XIV
