5000 PSI Concrete Availability
I work for a company that is based in the U.S., but we do work all over the globe. We have some standard designs that we use, and one of the new compatibility requirements is the use of 5000 psi concrete. My question is what kind of availability do you think is out there for this strength concrete?
RE: 5000 PSI Concrete Availability
1) It's a very common range for precast and multi story story columns.
2) With the high early strength mixes a lot of contractors order, it's hard not to end up with that much anyhow.
The greatest trick that bond stress ever pulled was convincing the world it didn't exist.
We did some work in the Solomon Islands and it was specified and used.
