Residential wind load design
I have read post on this forum regarding not using shear wall and diaphragm engineering on residential projects in high wind areas.Some designers are not providing drag struts or chords, not providing shear walls under diaphragm ends,using flexible diaphragms with no OM resistance, etc
What other method can be used to engineer a stick framed wood frame house? Has anyone ever designed a house a a large box beam?
Jeff
Jeff
RE: Residential wind load design
The greatest trick that bond stress ever pulled was convincing the world it didn't exist.
There are design pros who don't believe in the shear wall/diaphragm model for residential design. They say that many loads are statically indeterminate and the force path is unpredictable.And this may be true due to field conditions materials and craftsmanship, and inadequate design theories.
I have seen hundreds of 2 story houses built with the 2nd floor falling over the middle of the garage below.There is no design provision for the OM, but the house stands and resist high winds.
Now my idea is to develop a new method of designing houses as box beams or channels.The slab floor can be utilized as a web. Can this be done?
