dxfdwg problem
dxfdwg problem
dxfdwg problem
In UG NX 8.5.1.3 the translator (Start->All Programs->Siemens NX 8.5->Translators->dxfdwg)does not work.
A command prompt box flashes on the screen and nothing else.
I opened a command prompt window in the dxfdwg directory, ran the batch file with the proper arguments (double checked) and got a message that DXFDWG could not run because the UG directory could not be found. HMMMMM
So I changed the echo off to echo on in the batch file to see what was going on and ran it again.
It could not find UG because it truncated all the file paths at the first space. It was pointing to "c:\program"
Is there some way to add a code for the space character so it will not truncate?
I copied all the arguments from the icon that UG installed in the start menu.
Thank you.
Brad
RE: dxfdwg problem
I figured out that problem and now see what is flashing on the screen.
"Java version is 1.8.0_25
This meets or exceeds the minimum required version of 1.7.0_03
\java\jre1.8.0_25 was unexpected at this time."
Any help is great.
Brad
RE: dxfdwg problem
The problem will be that the UGII_JAVA_HOME variable isn't set correctly.
I just tested with NX8.5.3 and the translator works with that versions of Java (same as yours).
If your don't know how to set that variable:
Windows Control Panel -> System -> Advanced System Settings (Upper left) -> Environment Variables
Create a new user variable, the name will be: UGII_JAVA_HOME
Set the value to where your 64bit Java is installed. C:\Program Files\Java\jre1.8.0_25 is the value on my system.
Anthony Galante
Senior Support Engineer
NX3 to NX9 with almost every MR (18versions) plus the NX10 Beta
RE: dxfdwg problem
Thanks for the tip, but that didn't help.
Variable is set correctly.
Could it have something to do with 32bit vs. 64bit?
I am on a 64bit machine, but the IT guy installed Java in c:\program files (x86)
Thinking this might be a 32bit Java.
Brad
RE: dxfdwg problem
Check if you have 64bit Java installed because the translators need 64bit Java.
32bit is only used for the web browsers for NX docs.
Anthony Galante
RE: dxfdwg problem
That explains it.
I was having trouble with my help files, so installed a new 32bit java and removed the 64bit.
THANK YOU
RE: dxfdwg problem
Can the system have both 32 and 64 bit?
How do I set the variables so NX help uses 32bit and the translators use 64bit?
RE: dxfdwg problem
Just install 32 bit Java. The browsers will use it via reading registry and all the NX Java apps will use the variables that you set.
Anthony Galante
RE: dxfdwg problem
ok thanks
