Old SDRC Master Series
Repost from the I-Deas forum:
Hi Guys,
I am trying to keep a seat of Master Series 11 alive and running so we can keep old product alive while we hire people to remodel in Solid Works.
It is getting harder and harder. IT department needs to upgrade the server to Windows Server 2012. Does anyone know if it will run on this OS?
Is there ant resources I can tap into to try and keep this alive?
I'm also looking for a complete sets of installation disks for MS11, can't seems to find mine anywhere!!
There must be others out there in the same boat, let's share stories.
Dave Stevens
RE: Old SDRC Master Series
Tried that, thanks. It's a ghost town there!
I'm assuming that you're trying to get the TDM on Windows Server 2012?
As far as I am aware you need NX-Ideas 6.1 or above for working with Windows 7/Server 2012.
The older versions of Orbix won't install on the newer OSes.
The other trouble you will have is licensing and media.
Siemens won't issue a license for anything prior to NX-Ideas 5 (Ideas 13 in the older number format).
So if your license details have to be changed it's impossible to get that done.
With our access into GTAC, there isn't a version of Ideas for download prior to NX-Ideas 5.
Anthony Galante
Senior Support Engineer
NX3 to NX9 with almost every MR (18versions) plus the NX10 Beta
