Display 3d Sketches in Multiple Drawing Views
Hi, I need help to solve this problem. I'm trying to create a drawing for a boiler wall panel. Basically it's an assembly from 23 tubes created by sweeping two circles along 3d sketch. For the drawing I want to represent each tube as a single line, not as a solid model for simplicity and better visibility. The way I did this was to hide the solid body for every tube at component level and to leave only the 3d sketch visible. Assembly looks good, but in the drawing the sketch is visible only in the Front View. In Top and Left Views the sketch is not visible. I can make it visible manually, but first I don't understand why SW is hiding the sketch in the Top and Left, views, and second it's pretty frustrating to do this for a let's say membrane wall with 200 or so tubes. I've attached pictures if just a single tube which I think is enough to get the idea, but if you need more information please tell me. The pictures are numbered according the workflow. Any help will be appreciated. Using SW Premium 2011 SP2.0
RE: Display 3d Sketches in Multiple Drawing Views
I found this same problem dealing with Bend lines in drawings not showing up, even though it was turned on. We are using 2014 SP3. VAR found this doesn't occur in Sp5 2014 or 2015 SP0.
Scott Baugh, CSWP
FAQ731-376: Eng-Tips.com Forum Policieswww.superATV.com
www.scottjbaugh.com
Stoyan Petkov
Chris, CSWA
SolidWorks 14
SolidWorks Legion
Chris, CSWA
SolidWorks 14
SolidWorks Legion
Scott Baugh, CSWP
www.scottjbaugh.com
Have a nice day,
Stoyan Petkov
Chris, CSWA
SolidWorks 14
SolidWorks Legion
