ANSI B31.8 OR B31.3
ANSI B31.8 OR B31.3
ANSI B31.8 OR B31.3
I am doing a reliability study for a gas compressor plant in Maracaibo Lake, Venezuela. The plant is 40 years old and is offshore and there are no plans of it so I don't know wich was the standard used on its manufacturing. The question is, what standards should I use to calculate the minimal thickness of pipes, ANSI B31.3 or ANSI B31.8 for gas pipelines and B31.4 for condensate even if the lines are inside the plant?
RE: ANSI B31.8 OR B31.3
Greetings from Aruba.
Please post your email address.
Regards, John.
Hi John my email adress is fliaviloria@cantv.net. By the way I found the plans for this plant and I realize that was made under B31.3 Code of Design. Anyway if you want we to be in contact you have my personal email.
