Weld joint & Temperature derating factor
Hi all,
What is the definition & puprpose of subject factors in determining wall thickness of linepipe?
Thanks in advance
rizpet23467
Thanks in advance
rizpet23467
RE: Weld joint & Temperature derating factor
Do not leak under assumed design conditions of load, temperature, pressure, corrosion and erosion for the assumed lifetime of the pipe.
Add to racookpe1978, specified minimum yield strength of the pipe and the Safety Factor for installations in low to high populated locations, under roads and railroads and in compressor locations.
Public Safety!!! What did you think???
