Customize Hole callouts
When you use the Hole command in NX9.0 and dimension it in drafting, a standard text template is used. I was able to modify that by customizing the Hole Callouts in CUSTOMER DEFAULTS->Drafting->General->Drafting Standard. The result can be seen below in the attached picture. However I would like to change the depth callout to 2 decimal places instead of 3 decimal places. I am able to change it by going into settings and modifying the depth drop down, however I want to make this standard so I don't have to change it every time make a hole callout. Any ideas?
I'm aware I can change the standard dimension decimal places under the CUSTOM DEFAULTS->DRAFTING->ANNOTATION section, but this changes ALL dimensions, and not just the depth callout. I'e also search though quite a bit of the NX9.0/UGii folder, but didn't find any files that set these defaults that I could change the coding for.
Appreciate any help!
RE: Customize Hole callouts
Your path will be different, but find that file and open in UG and make your changes.
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Digital Factory
Cypress, CA
Siemens PLM:
UG/NX Museum:
