Ansys Mechanical - 2D problem
I have a problem in 2D to solve in mechanical. I have 2 questions with this simple problem:
1: I don’t know how to apply a distributed load. I just have the choice to add a force in the option. (Insert – force)
2: I need to add a support at half the length of a segment which is 2 inches long. I can only select the entire segment and I don’t know how to put to put the support to be 1 inch long. (Insert – fix support) Do I have to modify the sketch or I can do it in mechanical?
Thanks!
