What are points to be considered while stress analyzing a pipe which have D/t ratio more than 100?
Dear All,
I have a query. Will be thankful if you clarify my doubt.
While stress analysis of a line with D/t ratio more than 100 (48 inch flare line with standard wall thickness) using Caesar II, i found a warning that the SIF calculations are not proper. So sifs can be calculated using FE-SIF. What other considerations i should make while analyzing such lines?
Thanks in advance.....
RE: What are points to be considered while stress analyzing a pipe which have D/t ratio more than 100?
PAULIN has offered FEA tools(FE/Pipe) specifically developed to evaluate this type of situation
http://www.paulin.com/
Tell us more about your situation...... technically, with very low pressure systems, I believe that you do not fall under the piping code rules
MJCronin
Sr. Process Engineer
