Grinding using NX
Grinding using NX
Grinding using NX
Did anyone program for a CNC grinder using NX?
If so or if you kind of have an idea of how to do so, could you please share?
Thanks!
gnv
RE: Grinding using NX
What type of grinding are you talking about? A dedicated cnc grinder or a 4-5 axis machining center? If it's the latter I can connect you with someone who has done some amazing grinding using a trunnion table and custom bonded wheels.
NX9
Sorry, I can't help you with that one. Also I took a quick look in the support post library but didn't see any Huffman posts.
NX9
