about angular velocity input
Dear all,
I am performing a structural analysis of propeller blade in ANSYS Multiphysics. I want to apply centrifugal force in the ANSYS with angular velocity input in it. Propeller is rotating with 228 rpm .I have modeled blade and hub along with root fillet at the bottom of the propller. As blade is fixed to the hub of the propeller ,and which is attahced to the shaft. I have given the fixed bondary condition at the base of the propeller.
As i mentioned I am inputting inertia in terms of angular velocity at the centre of hub .Wheather it is correct method to apply it in multiphysics ? because there will be a boundary conditions addition to the angulare velocity .
If anybody has any suggestion on this analysis , I will be thankful.
SACHIN46
