It is enough to check a material certificate according to NACEif you don't have it mentioned?
I am checking the material certificates for some topside application parts.
Some have the NACE standard mentioned on it, some don't.
I checked the ones that don't with the NACE standard, and they seem to comply, but is this enough?
Delia Boboi
Delia Boboi
RE: It is enough to check a material certificate according to NACEif you don't have it mentioned?
How did you order the materials? If you require gold, but order rubber, you're the one to blame, not the supplier.
Too little info here.
The standard requirement includes NACE, but this is missing from the certificate.
Thus is the background.
Steve Jones
Corrosion Management Consultant
http://www.linkedin.com/pub/8/83b/b04
All answers are personal opinions only and are in no way connected with any employer.
