Beam Beam Contact Explicit
Hi
I'm having some problems trying to model beam on beam contact in Abaqus. I've been able to model beam on beam contact in standard by modifying the model keywords to include edge to edge contact formulation. However, the number of beam contacts is resulting in a slow or non converging model. Therefore, I've tried to simulate the same problem using explicit and general contact. However, the beam profile is not recognised in the contacts and the beams are passing through each other.
Could anyone shed any light on how I can resolve this? I've read that shell elements can be applied as a surface to represent the beam profile. However, I can't find much information on how I go about achieving this in CAE.
T
T
RE: Beam Beam Contact Explicit
