Extracting Associative Point Coordinates
Hi i am looking to extract the point coordinates of associative point in modeling to the spreadsheet. I plan of using these extracted points to fill out the information on a tabular not on the drawing side. The forum below sounds like what i would need but i cant get it to work in NX9.
http://www.eng-tips.com/viewthread.cfm?qid=217471
Any help or suggestions is appreciated!
RE: Extracting Associative Point Coordinates
Or you could just use the 'Spreadsheet Edit' function while in the Expression dialog which would automatically open a spreadsheet with all the expressions listed in it. You cauld then edit the contents of the spreadsheet and again save it to an external document which could then be used to populate your Tabular Note in Drafting. Again, there will be no associative relationship between the Expressions and the Spreadsheet.
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Digital Factory
Cypress, CA
Siemens PLM:
UG/NX Museum:
