Earth Fault Current Calcs
Ungrounded 11kV system is grounded through a neutral earthing transformer(NET) with impedance of 63 ohms/phase and neutral earthing resistor(NER)of 21 Ohms which yields an earth fault current of 151 Amps if NET impedance is added to NER i.e.
3xVp-n/(63+3x21) but if I consider resultant impedance of NET and NER then i get earth fault current of 213 Amps i.e. 3xVp-n/(sqr root of [63x63+63x63]).
Please advice if method is right.
Please note to make it simple i have ignored source impedances.
RE: Earth Fault Current Calcs
That is an approximation.
You have assumed that the impedance is completely inductive and ignored the resistance of the grounding transformer. There will be a small error. For an exact solution you must know the X/R ratio of the grounding transformer.
Normally the zero sequence impedance is three times the positive sequence impedance as determined by testing.
This is true if three distribution transformers connected wye:delta are used for grounding.
I don't know if this holds true for a transformer intended to be used for zero sequence current.
The question may be;
"Is the impedance of a grounding transformer reported as the positive sequence impedance or as the zero sequence impedance."
I don't know.
This will make a 3:1 difference to one term of your equation.
Others??
Bill
"Why not the best?"
Jimmy Carter
Thanks Waross for quick response. The grounding trf is zigzag type with zero sequence impedance of 63 ohms per phase
A close approximation:
Root([transformer impedance]2+[NER2])
or Root (632+212)
If the grounding transformer is tested for impedance voltage with the same procedure as a distribution transformer, then the zero sequence impedance will be three times the listed impedance.
That would make the equation Root ([63 x 3]2 + 212)
Hopefully one of the utility Gurus will post in on this point.
Bill
"Why not the best?"
Jimmy Carter
213 A is the correct value,ignoring resistance of grounding transformer.Normally grounding transformer impedance will never be so high and usually (V/root3) divided by neutral grounding resistor (ohms) will give the fault current as the effect of grounding transformer impedance will be negligible when vectorially added to R of grounding resistor.
When we say 63 ohms (X) as impedance of grounding tarnsformer, it is the phase value and the value between the zig and zag windings in a phase and hence is the zero sequence impedance.It is the value ( X/3) that we will get if V is applied between shorted line terminals of grounding transformer and its neutral.
